I have a complete turbo setup that was a pull-thru style that i modified to be a blow-thru. It can be used as a pull-thru agian with some minor modifications. It has Rayjay turbos for the pull-thru and RotoMaster turbos for the blow-thru, also has a 950 Holley (4150) carb that has the custom PV's for blow-thru but can easly be changed out for the pull-thru setup. The Rotomaster turbos are used but seem to be in good condition and the Rayjay turbos are fresh rebuilds (2 of them) and the rest are for parts. Not pictured is a water/meth injection setup that goes with it. I dont know much about turbo setups and i got cold feet and decided to go back to a big n/a motor. $2000 for everything. You can go to photobucket and look at the pics in full size under (Filucky)
Discussion Starter · #2 ·
Here are some pics of the setup on a BBC as a pull-thru (factory design) and some of a mock-up of a blow-thru on a BBF (w/BBC adapters)
Discussion Starter · #4 ·
A longblock BBC or BBF:D This was on a running 468 BBC in my TX20 two summers ago, as a pull-thru and it mad 18#s of boost (rayjay turbos)
