1 - 14 of 14 Posts
Monrovia in the House
I had some scratches so I wet sanded them with 2000grt the scratches are gone and the gel is good just need to get the shine back....Thank
What steps do I need to do?
What do I need to buy? polish, wax???????
New here
A wool pad on a rotary buffer. Orbital will not work at this stage, nor will a foam pad. I've tried all the combinations. I use 3M SuperDuty rubbing compound and a good quality wool cutting pad - first.
Then, I switch to a foam cutting pad and either stick with the SuperDuty or downsize to the Microfinishing compound (less agressive). This will get most of the swirls out.
Then, I would start with an orbital and use whatever glaze and wax you like.
I grew up working in bodyshops and sanding/buffing was one of the first things I learned.
New here
The foam pads really are great - AFTER compounding. Or, as I mentioned, as a SECOND STAGE of compounding.
Most of the So Cal marine manufacturers use a product called Rolite and green buffing rouge. Rolite is aluminum polished and was sold by L&L Marine. All they would do is apply the Rolite to the surface of the boat with a chip brush, load a buffing pad with the green rouge and buff the surface. You don’t have to worry too much about buffer speed as gel-coat does not burn like automotive paint.
Rolite sold out to another company. The same product goes by the name of Buff Magic. Diversified/sea land/quicksilver (all one company now) sells it to their dealers. Find one of the dealers and they can get it.
1 - 14 of 14 Posts
