1 - 1 of 1 Posts
Agressor 9 vane with bowl stuffer , very nice piece hard to find, has the forward bushing "spun" and will require some machine work $300 PM or call Tom @JBP
note:Re the bowl condition the rear bushing is OK the front is spun and needs repair the "rub" is that there is plenty of material to over bore and bush the forward are but the casting support area around the rear is/was cast rather thin This bowl could be run without a seal and plug but was designed to be grease lube and that parts (snap ring groove and seal area) is OK
1 - 1 of 1 Posts
