Engine Lifter ScreenS! Are they really what your system needs?? - YouTube
Sent from My BOOSTPOWER Efi Beacon
Oil going down dealing with air going up is a major reason I pulled the screens. The more you reduce the area, the more you increase the velocity of the air headed up, all fighting for the same space. Even of you have a Vac system of any sort, if the pan is in a depression, then the blowby had to go up thru the valley to get to that depression. It helps, but the gases are still flowing upward thru those slots.That probably wouldn't be so bad once the oil's hot...but add to that crank case pressure trying to come up through that screen, and now you have a problem, no matter how hot or tin the oil.
Heard of power gains from vacuum pumps pulling from the pan or the fuel pump boss as opposed to the valve covers also. Then instead of the blowby fighting the downward flow, the source of the depression is assisting it.It's crazy how much it reduces the ability for pan windage to meet upper engine windage to escape. The cam spinning, oil slinging does not leave a clear path. We actually make more power on a wet sump using oversize turbo drain bungs as equalizer lines to the heads! Fun stuff!👍
Putting the vac. down in the crankcase and behind the pistons is a great idea; unfortunately no one I know has found a way to do it without sucking a ton of oil.Heard of power gains from vacuum pumps pulling from the pan or the fuel pump boss as opposed to the valve covers also. Then instead of the blowby fighting the downward flow, the source of the depression is assisting it.
Depends on what side of the pump it's on. If it's between the engine and pump it has to be sealed and not sure how that would work. If it's on the exhaust side of the pump it can just go into the breather but I'm not sure about sucking that much oil through the vac pump.Lack of a better example, but, what about sucking it through a dry sump tank ? Could there be a small line from the bottom of the tank to the engine to allow the oil to drain back into the engine ?
Cost and simplicity. Bottom line is, taking vacuum out of the top of the engine works fine if it's done right.why not just use a 5 or 6 stage dry sump pump, and forget the vacuum pump and be done with it. After i went to a 6 stage dry sump pump on my twin turbo engine, i wouldnt use a wet sump system if someone gave me a brand new one.
That'll be impressive!Hey Steel, working on getting a 540 twin turbo done for my other boat with my new 29 lb each bullseye b480 lightweight turbos with the polished stainless v band exhaust turbine housings. Havent decided on which intake yet but leaning towards the dart tunnel ram which i have sitting on it dummied up right now.
If its a dry sump its best to just use a pump that is meant to be a vac pump, may even have a stage dedicated to just that. The best way with a wet sump is the best baffling you can produce and a LARGE air separator that drains back to the pan. Star makes a pretty effective separator.Depends on what side of the pump it's on. If it's between the engine and pump it has to be sealed and not sure how that would work. If it's on the exhaust side of the pump it can just go into the breather but I'm not sure about sucking that much oil through the vac pump.
on a related note..what is your thought on magnets?
