I recently switched from alpha to bravo, it used to trim out WO about 5/8 to 3/4 on trim gauge now it's trimmed out at only 1/4, why is this. Everything else is the same like prop, RPM,speed etc.
There is a little box on the side of the drive that is adjustable for your gauge.I recently switched from alpha to bravo, it used to trim out WO about 5/8 to 3/4 on trim gauge now it's trimmed out at only 1/4, why is this. Everything else is the same like prop, RPM,speed etc.
in trim mode the ram length should be 21 3/4 eye to eye + or- 1/4 inch this is the trim limit adjustment the rest would be in the sender.The sender is on the starbord side the limit is on the portI recently switched from alpha to bravo, it used to trim out WO about 5/8 to 3/4 on trim gauge now it's trimmed out at only 1/4, why is this. Everything else is the same like prop, RPM,speed etc.
right on, except its round.There is a little box on the side of the drive that is adjustable for your gauge.
