Mark is running a New century, and I am running a Brodix without any issues. Both of us have been at 30+ psi .how durable are they if i was to pony up for one? could i run big hp for long time or are they high maintenance? do they flex too much? etc. -thanks
With aluminum blocks being very common in production vehicles today I have to ask why you say this?You don't want an aluminum BBC unless you are racing or the highest end of lake boating.
yes, wondering why?:hmmm:......... i am against putting an extra 50-90 lbs in my boat form an iron block . i am trying to improve e.t.With aluminum blocks being very common in production vehicles today I have to ask why you say this?
have you noticed a pump pressure loss on top end with less weight or ill handling in rough water due to light back end?Mark is running a New century, and I am running a Brodix without any issues. Both of us have been at 30+ psi .
are you running an alumn block too?With aluminum blocks being very common in production vehicles today I have to ask why you say this?
Yes, my engine has a Brodix aluminum block. And I have been very happy with it.are you running an alumn block too?
Non of that BShave you noticed a pump pressure loss on top end with less weight or ill handling in rough water due to light back end?
oops! that ? was for ron.Yes, my engine has a Brodix aluminum block. And I have been very happy with it.
good to know!Non of that BS
are you running alumn too?You don't want an aluminum BBC unless you are racing or the highest end of lake boating.
Maybe he is considering a position on the IRF board of directorsYou don't want an aluminum BBC unless you are racing or president or vice president of the IRF.
is that is directed towards me :grin:? i am told that i should get a new block by my engine builder. #8 hole has been sleeved from a cylinder crack & started leaking after the repair. most likely from being a factory block bored .110 over pushing over 1100 (estimated)hp. lots of deck threads have been repaired from stripping out, water always in the oil, head not keeping flat,blown head gaskets,etc. . i read that the o-ring should be a figure 8 style instead of the way my block has been done (for alum heads).... a lot to think about . need to make a plan for next build/repair.Maybe he is considering a position on the IRF board of directors
first I would suggest he fix the issues he already has without tackling an aluminum block.
agreed.It was not directed at you.
Aluminum blocks are not worth the expense unless you are racing or are a serious lake racer.
agree more.Maybe he is considering a position on the IRF board of directors
you can make all the hp you'll ever want with an aluminum block. reducing weight will always help with et, if you are comparing the exact same hp numbers. but going to an aluminum block is significantly more expensive than an iron block.is that is directed towards me :grin:? i am told that i should get a new block by my engine builder. #8 hole has been sleeved from a cylinder crack & started leaking after the repair. most likely from being a factory block bored .110 over pushing over 1100 (estimated)hp. lots of deck threads have been repaired from stripping out, water always in the oil, head not keeping flat,blown head gaskets,etc. . i read that the o-ring should be a figure 8 style instead of the way my block has been done (for alum heads).... a lot to think about . need to make a plan for next build/repair.
Kevin won't race 1100hp jets..........:stir:I'd just be curious where this 1100+hp was when you were racing kevin. because I've yet to see a video posted where he's racing against an 1100hp jet.
my hull is very inefficient & my intake water pressure is lowagreed.
agree more.
Did the same machinist tell you to shit can that badly polished crankshaft, or is he the one that polished it?is that is directed towards me :grin:? i am told that i should get a new block by my engine builder. #8 hole has been sleeved from a cylinder crack & started leaking after the repair. most likely from being a factory block bored .110 over pushing over 1100 (estimated)hp. lots of deck threads have been repaired from stripping out, water always in the oil, head not keeping flat,blown head gaskets,etc. . i read that the o-ring should be a figure 8 style instead of the way my block has been done (for alum heads).... a lot to think about . need to make a plan for next build/repair.
