Did you do the test with the throttle butterflies open or closed? Sounds to me like you have a bum gauge...Should be somewhere close to around 150 PSI or so...
GT
hand
GT
You realize you're under total surveillance.:|errYeah, but then I deleted it when I remembered the cyber police are out and about.eh
Yeah, Bthntillidie, what GT Jet said
the motor has to roll for 3 compression strokes to get an accurate reading on each cylinder. Doesn' t sound like you did it that way.today i decided to do a compression check. Its a SBC 327 .30 over Full roller motor. I figured its simple enough.
So I went at it and the numbers seem way off. Not different from each cylinder just way low.
1)30
2)60
3)60
4)75
5)60
6)60
7)60
8)40
I thought they should be up in the hundreds? I would get it if one or two cylinders were 60 or 30 but all of them in that range?
I pulled all plugs on the respective side I was doing. either I am doing this wrong or this engine is done. I screwed in the tester and cranked it over with no coil. it will shoot to a number then rise to a specific number. it will slow when it gets to say 60.
is it me or the motor?
Cylinders with some heat in them will generally show higher static compression. It's a very comon practice in aviation, to do a run up, prior to compression testing.The only thing it seems is the Butterfly's were not open. I will try again tomorrow does the motor need to be warmed up? I have heard conflicting answers.
Its only worth a couple lbs warm to cold.The only thing it seems is the Butterfly's were not open. I will try again tomorrow does the motor need to be warmed up? I have heard conflicting answers.
borrow a different compression testerwell tried it again today. Cold Motor all the plugs removed, butterfly open
1)40
3)70
5)70
7)60
I turned it over until the needle stabilized.
Either I am looking at a bum gauge or a really bum motor. Does not makes sence for it to be the motor she runs fine out on the lake.
don't do the oil squirt, if the motor was runnin, the rings aren't stuck. all you'll be doin putting oil in the cylinder is decrease cylinder volume, and of course compression will go upSo next step is a a different gauge and ill ask some guys around my work for one so I know they good and calibrated.
First I will try the new gauge then if i get the same readings i will squirt some oil in there.
I was under the impression that if you squirt oil in there it will tell you wither it is the rings or not.don't do the oil squirt, if the motor was runnin, the rings aren't stuck. all you'll be doin putting oil in the cylinder is decrease cylinder volume, and of course compression will go up(same way it would if water got in there) just make sure the throttle is wide open, the battery is fully charged, and all plugs are out of it.
orielly's autoparts will rent ya a good compression tester kit
