1 - 17 of 17 Posts
Does anybody know the approximate amperage draw for a msd or equivalent
ignition system ? buddy of mine is building an airplane engine and wants to know if his alternator will be strong enough to handle all the demands ... thanks
Spiral out
I'd go straight to the source for that info...........but I wouldn't talk to a salesman!
Might even try Steve Brule over here......... http://www.westechperformance.com/contact.htm
He will likely know who to talk to if he does not know.:D
Ummmmmmmmmmmmmmmm...................... Do I dare assume there is a variance in the aircraft's certification that permits this instalation, or in the engines mfr's certification, or that your buddy is getting an experimental certificate from the FAA for his about-to-be illegally-modified airplane?
FAA only plays nice when you follow their rules.
Boat Nut
Whole different ball game with home builders, they can run what they desire as far as power plants go. The only restrictions they have, is equipment required to fly in controlled airspace, and IFR flight
Like I said, he'll be flying on an "Experimental" type certificate then.
Good question, I have not a guess on that one. I would suspect probably so tho, if it is designed with seating for such.
So you can experiment on buzzing people,cars,boats.
Its fun coming up from behind them;)
Well, that would be "practicing" actually. LOL. :D
Good luck to the guy MSD'ing his bird. I work in aviation and would never wish a bad landing on anyone.
(A "good" landing is one you walk away from). :D
Boat Nut
Had a customer put a Lasar brand electronic ignition / mag, in his Piper Cherokee six. Almost bought the farm twice, from mag failure. Both times were on practice approaches, went to pour on the coals, but nothing was there. He declared an emergency landing for the first incident, and made it. The second time he was gonna be short, but the mag came back to life. The system had a fail safe, it failed twice on him, they checked it out both times by the MFR, but never got re installed after the second time.
Well, while not a 100% guarantee, this looks pretty convincing.
1 - 17 of 17 Posts
