sorry for cell phone pic, posting this for a friend and will get better pics and more info later. Have not seen an intake like this one yet
That is a Alpha marine low profile intake. We used quite a few at Eliminator. Found out later it was not as good as some of the other low profile intakes so we stopped using it. Good up to around 120 mph and then has some loading issues.sorry for cell phone pic, posting this for a friend and will get better pics and more info later. Have not seen an intake like this one yet
Alpha 5°, I believe Greg Shoemaker told me they were designed with a wide flange to bridge the entire pod on a daytona, maybe he can chime in.it is in a 90' placecraft that was laid up by canyon from what we were told, if that helps
Guess i was too slow, :duh:That is a Alpha marine low profile intake. We used quite a few at Eliminator. Found out later it was not as good as some of the other low profile intakes so we stopped using it. Good up to around 120 mph and then has some loading issues.
How much power in the Placecraft?thanks greg and josh, that is the one. does this deal use a standard loader pad or ? At this stage in the project it would be the time to change it. what is the trick set up for placecraft, MPD?
The same loader will point higher in the alpha compared to installing it in a Berk intake. Plus it puts the ramps quite a bit closer to the impeller. We had to bring the ramps down and trim them back on the loader we installed in our mach 1, which had one of these intakes also.thanks greg and josh, that is the one. does this deal use a standard loader pad or ? At this stage in the project it would be the time to change it. what is the trick set up for placecraft, MPD?
