Go to the web site of the rod manufacturer and follow what they said
Let me show you why what Infomaniac posted is so important. This table is from Callies/Compstar's website, for Compstar rods and ARP bolts.
The first 2 are 2000 bolts, the last one is a L19 bolt. Notice the torque value for BOTH the H and the HD I beam are different, but the stretch is the same. FOR THE SAME BOLT!!
What happens is, if you torque the 2000 bolt to 85 lbs in their H beam rod, the bolt doesn't necessarily stretch more, the ROD CRUSHES AND DISTORTS! It can't stand up to the clamping forces of that bolt torqued to the value. But the HD I beam is much beefier around the big and it can.
Look at the torque value of the L19 in the same HD I beam. 92 LBS!!! Look on Eagle's website for the same 2000 and L19 bolts. Its 75lbs (2000) and 79 lbs(L19). Its not that the L19 can't take more torque, its that the ROD CAN'T.
But the chart below shows that the 2000 bolt is capable of 85 WITH ARP LUBE! compared to oil used in the OP's Eagles. 10 additional LBS for oil is not uncommon.
What does all this mean. The 2000 bolt can take 85 lbs IF it results in a .005-.006 stretch. Or maybe even 95 with oil.
However, the rod might not! Eagle rods are not famous for keeping there shape under the torque Eagle recommends. I have measured Eagle bores out of the box, and after retorquing them, and the bore changes. I can imagine it would REALLY change if I over torqued the fastener.
The question is, was the fastener over stretched by pulling it to 95 with oil? Or did the bore simply get racked?
Bottom line, I would replace the bolts, check the big end for roundness, AND INSTALL THE NEW BOLTS TO 79-80LBS WITH ARP LUBE.
One last thing. NOT ALL 2000 AND L19 ARP bolts are created equal. 2000 and L19 is only a material. The Callies bolts have a different cross section between the head and the threads. Eagles bolts have more of a undercut and stretch to length at a lower torque than others. THIS IS THE SINGLE MOST IMPORTANT REASON YOU NEED TO KNOW THE BOLT AND THE ROD YOU ARE PLAYING WITH. What Eagles bolt and rod need is different than what Callies do, even with the same bolt a MATERIAL!
Big Block Chevy Applications:
Designation Style Thread Length Torque Stretch
BBC H-Beam 7/16-20 Thread 1.700″ 75 ft lbs .005″-.006″
BBC HD I Beam 7/16-20 Thread 1.700″ 85 ft lbs .005″-.006″
BBC HD L-19 I-Beam 7/16-20 Thread 1.700″ 92 ft lbs .005″-.006″
