I would recommend the 917602, steel, 3 rib, 8". I think for your app it will provide better damping for the stroker and a little more inertia for cruising.Steel or aluminum hub? Which to use and why? 2or 3 piece?
You going for some sort of 1/8-1/4 mile et record? Will you be hooking this to the front of your Extreme Ludicrous Light crankshaft with Ultra Lightwieght rods and flyweight pistons?
so that would be the 917062 :wink2:I would recommend the 917602, steel, 3 rib, 8". I think for your app it will provide better damping for the stroker and a little more inertia for cruising.
:duh:so that would be the 917062 :wink2:
