1 - 7 of 7 Posts
· Registered
Go see Liegh at Automotive Specialties on Diaz (Blackdeer loop and Diaz area over by the DMV) and tell him the boys at PDS Fabrication sent you. He seems to be the best in the area since Grahm sold Temecula Radiator/Auto Repair. :)hand
· Registered
Sounds like the blower motor resistor, our shop in Fontana just replaced 2 in the last month part is about 75 bucks from the dealer resister is located under dash on passanger side 2 screws hold it in mounted on blower motor housing. Just follow wire harness off of blower motor it runs to the resistor.
· Registered
Discussion Starter · #7 ·
I'll check that out. Is there a way to test it? I can put a meter on it but what should resistance be? I suppose if there is no continuity at all it's bad?
1 - 7 of 7 Posts
