1 - 11 of 11 Posts
If you have ran your engine with a flywheel for years and need to change it over to a flexplate , will this change have a big affect on the engine ?
i'm really not sure about the big effect, but, it sure will save a bunch of weight :), thus, its gotta help some!
FastRat
No Sandbar To Far
Is or was the motor balanced? If so, internal or external? M
I need to do the opposite. Flexplate to a flywheel. External balanced.
Sooooooo.................. Yes or no..... changing the flywheel to a flexplate won't affect the engine.
Its ext balance.
This is my problem, I originally set up the boat with a BBC 454 with a flexplate... Now i bought Beerjets engine and it came with a flywheel.
Now the engine needs to be moved forward about a 1/2" to make up the diff and need to buy longer bolts to install, PTO and flywheel..
Or i just buy another flexplate and put everything together:)grn
I just want to make sure im not going to hurt this engine
Its ext balance.
Take the balance card and the old flywheel with the new flex plate or vise versa to a decent machine shop that does balancing and if he knows what he is doing should be able to figure it out. External balance is putting everything in-balance on the ends of the crank that is not in-balance inside the motor. Factory uses a scale of in balance and not. That would be why you have weights on the balancer and the flywheel/flexplate. A good balancer will get balance within 1/4 gram, inside or out. I would try to get as close to the balance card as possible.
Sit N' Spin
2sav...you kinda have to have an engine for it to affect in the first place :D :)hand
1 - 11 of 11 Posts
