I started this build for a customer about 5 years ago. The Campbell 24 it was for still hasn't been worked on to accept any power, That started 20 years ago....
Anyway he has a new toy that had a transmission problem and is OK with a new motor for the 40 mph 20 ft Campbell.
I took the trans to Art Carr and got it fixed the right way. Thanks Art !!
I found the 454 that was in the boat was a crate motor. It was the wrong crate they picked up...... Peanut heads, Cast flat top pistons, Cast crank, Stock cam ect. Maybe 50 hours on the motor. I would have been a good motor for a dually or motor home ??
So anyway, The 4 bolt main block is .030 over and is in good shape for this turbo build. The parts I have been storing : 4.250 stroke forged crank, 6.385 I beam rods with Wiseco -3 cc flat top pistons. The heads he ended up with are Bravo 335 rectangle port aluminium with 123cc chambers. Also an old style SP2P intake manifold.
So I'm stuck on the cam shaft for this one, Banks says they don't have any product info on boat motors because they aren't building them anymore. It looks like my customer wants a Crower hydraulic flat tappet turbo cam shaft. Has anyone run one of these? I'm not a turbo engine guy so I couldn't even argue this selection of cam. The springs are good for up to .560 lift.
I'm trying to keep the cost down so I can finish this thing. Turn key low maintenance. The boat owner isn't a hot rodder and is easy on equipment as they come. Just trying to get some reasonable speed out of the boat and keep the twin turbo nostalgia look.
Thanks,
David
Thanks,
David
