1 - 10 of 10 Posts
Some guy
Posting for a friend, parts are currently in Parker, AZ.
6.535"(.400" longer than stock) long Carrillo Rods with SPS CARR bolts $1000 Matching set, no visible damage to rods. https://www.summitracing.com/nv/parts/cnn-c42776535s08/overview/make/chevrolet
Crane roller rocker arms (only 14, missing 2) $100 Buy two to complete the set (https://www.summitracing.com/nv/parts/crn-13750-1/overview/) or use these for spares. Note the three sitting upside down have some cosmetic damage.
BDS BBC blower idler bracket $60
BBC blower crank hub, externally balanced, mint condition (not sure hit has been run) $100
JE 632 cu in coated pistons. 4.600" bore, 4.75" stroke, 1.12 CH flat top. about 500 miles street use (under 4,000 rpm) $300 with pins and oil ring supports.
Edelbrock BBC cast valve covers with push in breathers, gaskets and stainless fasteners $175
Some guy
I'll take the blower crank hub. you can text me cost with shipping to 98682 to 360-910-3451. Mike
I guess it will fit in a small priority mail box, but I picked it up to check what size box and noticed that someone has pried on it apparently. Didn't see these marks on the back side of the hub when I posted the thread.
Precision Craft Marine
If you haven't sold the Hub or Idler bracket, I will buy them from you. I am looking for other stuff too, may you have them. Joe
Some guy
Looks like the blower hub is sold, it's possible I have another one with a counterweight here, I will check.
Some guy
Didn't mean to let this drag on so long, I have a couple more drive hubs, and need to shoot photos of the 8mm pulleys and belts that I have as well.
I Pm ed you , I will take the bracket for sure. I will also figure out a few combo's and possibly buy some of your 8 mm pulleys. Thanks again. Joe
1 - 10 of 10 Posts
