1 - 2 of 2 Posts
Has anyone ever had any problems with cam bearings in the BBC...Im building a 496 and installed the cam bearings, but the camshaft will not fit through the second or third bearing. I removed the cam bearings and they fit over the camshaft fine, but not while in the block. Its almost like the camshaft bore is too small, and yes the bearings are in the correct journals...Any suggestions??
1 - 2 of 2 Posts
