1 - 2 of 2 Posts
Getting ready to take my Motor to the dyno, Blown pump gas 509. I have both short and long collector Bassetts, Which ones should I use and why? I looks like the fast GN guys use short collectors? Will my Magna flow pump work on the dyno? I thought about using my electric setup but it wont work whith my idler bracket. Thanks again for the advise, Tom
The set of headers with the bigger tubes, if that's a choice. Typically the dyno will have it's own headers with EGT and 02 bungs, but it's alwayas good to test your own headers. Try them both and see what the difference is. That's what the dyno is for. Yes, you can run your water pump. You;ll just have to figure out how to plumb it into the cooling tower.
1 - 2 of 2 Posts
