Turbo, where do you come up with these ideas?
You are aware that an oil that is any larger than meets the requirements of the engine just bypasses the excess and heats up the oil. It accomplishes NOTHING.
You disconnected the oil cooler, and what to make up for it by going to a larger pump.
.003 and .0035 is not that huge. If you think they are larger than that now because the crank has been polished, then think about tightening them up.
My GN runs at 35 psi idle hot and 55-60 psi hot at 7000+ and I have never hurt a bearing with that pressure. Lost a few when there was NO pressure.
If you have 60-80 hot, you're just fine.
The only difference between a System 1 pump and a Melling 77HV is the cap is modified to discharge the bypass into the pan instead of the pickup inlet. It does not tmove 1 oz more oil.
The Titan is a superior design to the gear pump, but it doesn't move much more oil than a HV 77 either,. Also your pan needs to be modified to accept the Titan.
You are aware that anytime your Mellings pump is pushing 65 psi it is just bypassing oil. Its in full bypass at 75 psi. How much more oil are you looking to bypass?
Like having turbos big enough to make 60psi at WOT, but your BOV is set at 40. WTF!!!
Q:Turbo, where do you come up with these ideas?
A:what idea? of higher volume oil pump? i did not think of it, it was already thought of.
A: MY last batch of BEARINGS DID NOT LOOK GOOD & i had the oil cooler on.
A:
i ran wot & had only 40 psi of oil
Q:You are aware that an oil that is any larger than meets the requirements of the engine just bypasses the excess and heats up the oil.
A: no i was not aware that if the pump is in bypass it heated up the oil (good to know,thanks)
. i thought that if it idles cold at 80 psi that the bypass would be set at 80 then. i thought once the oil heated & dropped to 60 it might be beneficial to raise the flow to be at 80 instead of 60 wot. i also though the more oil that flows over the bearing that it cools them better. i also thought about using synthetic to let the turbos spool quicker & cool the bearings too(ceramic bearings on turbos).
Q:You disconnected the oil cooler, and what to make up for it by going to a larger pump?
A: no ,i said even with the cooler hooked up it gets pretty hot quickly. i said that i slow it down & let it cool off when i see 45psi of oil. i don't want to have to slow down to cool the oil off as often as i do on the river for instance.
Q:.003 and .0035 is not that huge. If you think they are larger than that now because the crank has been polished, then think about tightening them up.
A: yes i think i need to have it checked, it is on the agenda.
Q:You are aware that anytime your Mellings pump is pushing 65 psi it is just bypassing oil. Its in full bypass at 75 psi. How much more oil are you looking to bypass?
A:no i did not know that it is in full bypass at 75psi! not wanting to bypass any i guess. was hoping for a different pump that would NOT be in full bypass at 75 psi. i noticed earlier in the year it was going up to 80-85 wot building psi .probably first or second run of the day.after that's when i did not pay attention & heated the oil & ran low psi on some wot runs. maybe the bearing issue is boiling water vapor scorching the bearings when vaporizing in the oil at the bearings instead of oil pressure problem?
Q;
A: wtf? i believe i have a real concern about getting a bit more oil to the motor,even the cam doesn't look very good. kind of like insurance if not needed & a must if needed.your motor runs great with what pressure you are running & mine looks like dog shit . i want to get my pile right. this is not fantasy internet racing , i run the crap out of mine & have real issues. -thanks for the info provided
so, if it certain that i will need more oil , will a titan oil pump heat the oil less if bypassing than traditional oil pumps? i understand they can build one for what i need ,volume,pressure etc..
is there something slightly better than the mellings hv that i could possibly beneifit from?
maybe a bigger oil cooler might be the way? if one will fit.
could the problem be that it is a stock block & does not have priority oiling?
