NEW PRICES-
NEW Herbert billet solid roller cam 629 lift, 114 lobe center,242 duration @ .050. good cam for blower or turbo.
125.00 plus ride
New Herbert vertical bar solid roller lifters standard OE size.
150.00 plus ride
New Mahle BBC270280F03 forged flat top pistons 3.280 bore,1.270 compression height. Coated skirts and phosphate coated for initial break in. chromoly wrist pins and plasma moly rings would use with 4.250 crank and 6.385 rod.
350.00 plus ride Would cost 775.00 at summit.
Used comp cams solid flat tapet cam. 11-219-4 . Comes with lifters. Lobes checked good.
45.00 plus ride
Used eagle press fit I beam rods with arp bolts. Has pistons attached, can have them if you want to pay to be shipped or I will press off. 80.00 plus ride
Factory forged 4.00 crank. Rod journals @.020 need to polish mains at .010 need to be cut.
150.00 local pickup or meet halfway IE OC SD LA.
Two bolt block standard deck has not been cut. .030 bore needs to be bored and hot tanked no cracks. 100.00 local pickup or meet halfway IE OC SD LA
Having problems posting pictures email me at [email protected], txt 951 214 0460 or PM me for pictures.
125.00 plus ride
150.00 plus ride
45.00 plus ride
