1 - 14 of 14 Posts
I have a polished vacuum pump kit for sale that has been used twice on a Reher Morrison drag motor. The kit includes:
Three Vane Vacuum Pump
Brackets and Pulleys
Mandrel Drive System
Breather Tank
Stainless Steel Lines
Two -12 AN 90° Fittings
Two -12 AN Straight Fittings
Also included in the sale are a set of fabricated BBC valve covers with welded bungs to run the pump.
New Price... $750 plus ride takes everything
" Live Laterally "
This is what we run on the V-Drive and it works awesome!
I believe that it will clear. I have seen a couple setups that run a vacuum pump and a blower. You will just have to play with the spacing on where you mount the pump to line up with the pulley.
1 - 14 of 14 Posts
