1 - 12 of 12 Posts
lets try this here, does anyone have any plates for a bbf for a rail system or know where i can buy some?
www.highflowdynamics.com
I hear that Jet Boat Performance has come out with some nice kits. I also seem to recall Duane at HTP offering one as well.
Or you can make your own by using a timing cover (front engine plate bolt pattern) and block plate (rear engine plate bolt pattern).
LO
Thanks Paul! Slotty heres what Josh designed and we have been using with good sucess , 3/8 thick, CNC precision water jet cut DIY friendly PM me if we can help Tom
Pro Gas Jet
ford
beautiful plates. They should fit the Boss 429 block. right? yeah they are the same !!
Those are sweet....I'll try to remember you have them.
S CP :D
Pro Gas Jet
wilder
yes you do !! you need to order them now for your wilder. the time is now !!!
Yes I belive so Paul (LO) may have to Chime in on that and Thank you !
S CP :D
Thanks John, Josh learned/self taught CAD in record time last spring to produce these as well as several other new products for us debuting soon , very proud Dad here ;) !
if anyone wants to see them in person I run them on Ginger and you can see them next weekend at that one place well be hanging out at. ;)
I designed these up and had IronMan on the boards water jet them out for me. hit him up, hes still got the files to make additional sets....
he has not been on here since june
1 - 12 of 12 Posts
