1 - 10 of 10 Posts
N/A with the no2 every now and then at about 7200 rpm with synthetic 15/40 oil. What would be optimum clearances...main and rod???
rods measure in at .0025 to .0027 with a side clearance of .024-.025
Mains .0028-.0030
Good to go, or add just a little more?
I have never flirted with the 7k rpm range, so im just double checking.
I wouldn't run any more than what you have. I'd probably shoot for .0023-.0024 rods, .0025-.0026 mains and run a 10w oil.
Bostick Racing Engines
Mains .0028-.0030
If everything is straight, round, and measured with something somewhat accurate... run it.
You'd be surprised at what you can get away with when all the machine work is correct and done right...and what you can't get away with when it isn't.
Btw... what are you using to measure to arrive at these clearances?
1 - 10 of 10 Posts
