I've got a mark IV bbc. I need to replace the pins for longer ones. How do I get the old ones out and the new ones in? Thanks.
Tim
Tim
You should be able to knock them out with a punch. There should be a small hole on the front side of the block in line with the dowels. Install the new ones with a brass hammer or a regular hammer and a block of aluminum or brass. Use some lube and make they start straight before you drive them home.I've got a mark IV bbc. I need to replace the pins for longer ones. How do I get the old ones out and the new ones in? Thanks.
Tim
They can be pretty "stuck" some times. Little penetrating oil, little heat certainly can't hurt.Thanks for the responses. I wasn't sure if I need to heat the block with a torch. Didn't want to break it trying to drive them out.
Tim
