I have a 12JG berkeley and pulled the two plugs on top of the bowl to ad recomended 90 wt to it, and according to most discussions I've read... the oil should come out the oposite hole when full! but it never did that.. it just started to drip out of a small hole on the underside/bottom of the bowl, I put almost a quart in and about a half pint dripped out of that hole and it quit. does this indicate some sort of a seal problem in the bowl because it didn't just come out of the oposite hole, or is that normal to seap out the bottom hole when full? Thanks
