1 - 20 of 34 Posts
i would like to know if anyone has ever had a thrust bearing go out and what kind of noises it made. ever since i got this boat it has had a strange growling noise only at idle to 1300 rpm im pretty sure its coming from the pump. also if the wear ring was bad would it make this growl. i have put at least 30 hours on it and it has not got any worse or better.
not ******
My first jet did that and come to find out, people will also say that it can come from where the drive shaft meets the pump on that splined shaft, i will not have a postive lock with each other until under constant throttle. can be from the cam/ idling it wont make full contact causing that kinda grinding/ moaning noise . just something else to think about.
I had a bearing fail. The sound is a growling, grinding kinda sound that kind of goes away but it just a higher pitch sound while under power. Lucky for me I had enough room between the crank and the Hbar. I did get the crank hot enough to melt the 1 piece rear seal.
I have a stainless thats noisy at idle. I had the pump freshed up and thats the noise it makes with a stainless impeller.
jetboataholic
Why does a stainless impeller make a growling noise?
cave mentioned when his bearing failed it got real hot at the thrust bearing mabey i should run it this weekend and check that out. i do have some play in the shaft splines also. is there anyway to repair that without changing the shaft out.
mine growels a bit. it used to freak me out. I'm counting on the stainless theory. cs19 said it was the shaft at idle. grrrrrrrrrrrrrrrr:)sphss
I would suggest NOT taking a chance. Its a bitch if you have a 2 piece seal plus if the forward thrust is great enough it could damage your crank or worse. Your impeller wants to move forward. Any play or give will allow it to do just that. If the bearing fails. The impeller will take out the Thrust bearing in the rear of the engine.
I had that growl and to be safe I had the pump freshed up. Everyone said the pump was OK but I had to know. I think they call it Piece of Mind. Now the sound doesn't bother me. Its a jetboat:)devil
Good Luck, cave
Check U-Joints thay will make the same sound.:)(rivertard).
Discussion Starter #12
ok i just removed the thrust bearing cap to find out thrust bearing is bad. at least thats what i would assume if ball bearings came flying out. looks like i'll be pulling the engine to get the shaft out the front to press bearing on and off.
growel our ass.:D At leasat you caught it early before it hurt motor. does shaft have to come out. i have my motor out for build and amd wondering how easy it would be to replace. after removing the cap can you slide the bearing off the shaft and put a new one on without having to take pump all apart? i know for some that might be a stupid question but i am here to learn about the steps. i might be way off.
Depending how strapped for cash you are, It would be a good time to freshen up the pump. Now that your going to pull it out. Do a pump rebuild. If your Impeller is good then its just bearings & seals. You can get all the stuff you need form one of the guys here. JBP, HTP, REXMAR or CPP.
Better find out now than summertime.
jetboataholic
There ain't no sliding to it!:D The bearing is a press fit. Plus, there is no way to get a hold of the bearing to pull it out. The pump has to be completely torn down. Once you get the impeller off, the shaft has to come out the back of the pump, the bearing will still be attached to the shaft. Then, take the snap ring off, and press the shaft out of the bearing. Lastly, repeat the steps to put new bearing on and pump back together.
Here is a link to a good overhaul manual for the Berkeley pumps, it has pictures.:D BERKELEY OVERHAUL MANUAL
Not sure if the link is going to go to the right place so here are instructions on how to get to the manual if the link opens up the homepage. It is www.americanturbine.com. On the site click on "Support", then "Downloads", next "Overhaul Manuals", lastly "Berkeley Overhaul Manual", this will open a PDF file with the manual in it. I printed it off and put it in a 3-ring binder that I keep out at the shop, if I ever need to look at something or if someone else wants to see something. Hope this helps.
All right, the link worked for me!
Discussion Starter #16
yes hawaiianjet is right its a pressed fit bearing. im hoping ill be able to break the impeller nut loose i cant find a wrench anywhere to fit it. berkeley says its a 1 13/16. no one has that size wrench in this crappy town.
jetboataholic
Do like I do and use a pipe wrench or a big crescent wrench from "hazardous freight", very cheap way to go. Also, put a pipe wrench through the hand hole to hold the shaft when removing the impeller.
i just had a stage II rebuild done 2 years ago. i would think all seals and bearing are good to go. i will take thrust bearing plate off to take a look at it.
make sure bearingsarent falling out. i havent had any slippage or howling sounds. just an occasional growl on idle.
thanks for the expalnation on this part of the pump ( cave, hawaiian and challenger). always nice to learn something and good luck with your project.
Jeff
jetboataholic
Jeff
Make sure it has lots of grease in it too.:D The good red stuff. Grease is very important.:D Makes the bearing last a lot longer.:D
B1 Racing
when the bearing falls apart like that when you pull the bearing cap youve got issues..
alot of times jetboats will have that growl at idle or low rpm, its the driveline usually.
1 - 20 of 34 Posts
