1 - 20 of 26 Posts
Amber Racing Services
Used Berkely 304 Hi Chrome S/Steel Alloy shaft w/ thrust bearing, S/Steel Sleeve (slinger ring), oversize retainer ring, no thread or shaft damage and is ready for installation ... just going to a Aquamet shaft, only reason for replacing
$100
DOES NOT include shipping costs ... shipping is extra.
Brian
949-870-5773 cell
Will it fit the old style Dominator pump ?
Yes it will.
I spoke to Jack at MPD about this and he said that the only difference is that the seals on a older Dominator are a different so you would have to use the sleeve where the bearing is from the Dominator shaft on the berkeley shaft to seal properly.
But it will work perfectly.
B1 Racing
some of the older dominators use an old style suction seal which means the shaft collar (where the seal rides) has a larger OD than a standard/modern collar. your suction piece could be machined for a modern seal and you could run a modern collar and seal. Ive machined dozens of suction pcs. for this.
Thanks Chris ... how does he know which he has?
the area where you shim the impellor is different lengths between berk and dominator shafts as well;) 1 is almost a 1/8th inch longer in that area(the dom is longer).
You still have this for sale ?
Yes I do, totally forgot about it to be honest. And that led me to looking around my garage ... christ I have too much crap.
$100 plus shipping. It's about 13lbs, so add a couple lbs for a box and you can check out UPS, USPS, etc.
Probably about $25 to ship up to Washington.
Brian
949-870-5773 cell
Just Me
Brian
949-870-5773 cell
Don't suppose you found any old eliminator goodies that fall into that too much stuff catagory?
best thing to do is start a WTB thread about what you need, I'm sure I will have some of it, but the others will have the rest.
1 - 20 of 26 Posts
