1 - 13 of 13 Posts
Hey can anybody tell me this answer. I have a 19 ft carabean with a new 545 stroker moter tunnelram roller rockers aluminum heads.I am not shure how many horsepower it has I believe at least 500 hp, My question I have a Jacuzzi wj pump on it now and I can not go over 50mph would I get more top end speed if I put the Berkley jc pump on.
Something is wrong. What is the RPM you're seeing at WOT? If you just stand on it from from a float does it act like a slipping transmission? Tom at Jet Boat Performance will chime in here. Listen to him, he knows his shit and is very fair!
berkley vs jacuzzi
no it will jump right out of the water, I did not check the rpm,s at that time but it was close to full throttle. I do have a place deverter on this jet also and it wont even shoot a rooster tail. could it be the jet is being restricted.
What the Hell is That?
Think about an energizer kit for your pump...swapping out for a berk. can be done, But it's a lot of work
Not necessary to swap, A good WJ will stand up to a berk any day.
Being it's not throwing a roost I am leaning towards the PD. is it hanging up on something, cable hard to push pull etc? Maybe it's constantly pointed to far downward? Where is the Handel when your on plane?
Without a droop or something similar you shouldn't get a huge rooster tail.
I had an old jacuzzi in a Cheyenne with a 600 HP bbf would run 90. You have something not right. Hull? Lower? Tune?
vacum
can someone trll me I just installed a tunnel ram with 2 holley 600 carbs with vacuum secondairies, I have a unilite distributor with no vac advance. where can I get vacuum for the secondaries should I install a vacuum port from intake? any advise would be helpful thanks
Seriously off center
Vacuum secondary diaphragms work off internal vacuum ports, not an external vacuum source. To tune them you'll get to know the different springs and possibly make an equalizer for the secondaries
Discussion Starter #12 (Edited)
mini startr 460 ford
can someone help me im trying to wire this new mini starter, not to sure where to connect wires. on my old starter the big battery cable and the red thick wire went together on the batt terminal, the white wire went to the "s" terminal and the orange wire went to the "r"terminal.On the new mini starter there are only 2 terminals ???? I know the main batt cable goes to top teminal not sure about the others help
can someone help me im trying to wire this new mini starter, not to sure where to connect wires . on my old starter the big battery cable and the red thick wire went together on the batt terminal, the white wire went to the "s" terminal and the orange wire went to the "r"terminal.On the new mini starter there are only 2 terminals ???? I know the main batt cable goes to top teminal not sure about the others help
Buy a diode from radio shack and tap into the white wire with momentary current flowing to the orange wire during the crank ( orange goes back to the coil or ballast resistor, 12v crank circuit) The idea is to give a 12v "boost" to the ignition during the engine cranking , your white, yellow or white with a trace is typically your starter S wire
1 - 13 of 13 Posts
