24 is the most common with a 496. you can pull a 22 and it will make a huge difference in your bottom end, but, you will lose it all on the top.What is the best prop for a 28 magic deck with a 496 HO it has a 24 but seems to take forever to plane out especially when fully loaded with gear and people is a 22 a big enough change im not too concerned with top end
I have the same boat and prop. mine gets on plane 1 1/2sec. I roll the throttle to full throttle w/ my drive all the way down. once i'm on plane i pull throttle back and away i goWhat is the best prop for a 28 magic deck with a 496 HO it has a 24 but seems to take forever to plane out especially when fully loaded with gear and people is a 22 a big enough change im not too concerned with top end
Right on target......I think the key is to tuck the drive, roll into the throttle and do a little S turn. The S turn seems to shift the weight and get the boat on plane a little quicker....
Mine wont hit the rev limiter with a 22 full with 4 peopleI don't know if it's weight distribution or what, but the Magic hull seems a little slower to roll over then other deck boats I have ridden on. I think the key is to tuck the drive, roll into the throttle and do a little S turn. The S turn seems to shift the weight and get the boat on plane a little quicker.
If you have the boat loaded up with people, fuel and gear a 22P might be the way to go, but I would try it and see where your rpm's are at wide open throttle. You don't want to run it on the rev limiter.
WHAT.how in the hell are you getting on plane so fast?what motor/prop and are you running trim tabsI have the same boat and prop. mine gets on plane 1 1/2sec. I roll the throttle to full throttle w/ my drive all the way down. once i'm on plane i pull throttle back and away i gohand
I think his clock is a little slow.Mine wont hit the rev limiter with a 22 full with 4 people
496ho 24p no trim tabs. I have never had a problem with getting on plane never had to do the S turnsMine wont hit the rev limiter with a 22 full with 4 people
maybe a littleI think his clock is a little slow.
Tabs are a nice addition, but the bottom line is that if all the other gazillion Magic's are working fine with a stock 24 Bravo One prop, this boat should too. Find the problem before you start throwing other stuff on there.
