It isn't hardened, you are either using a dull twist drill or you are spinning the drill too fast.I have a broken exhaust bolt on my rhino and all the bits i have tried to use to drill it out have failed. What do you guys recommend to get the bolt out. Thanks for the help.?
They arent cutting and a few have brokenTungsten carbide would be my choice, but I'd use a reverse cut bit no matter what I was trying to remove.... 99% of the time the bolt will come out before you even have to try and get an easy-out in there.
When you say they've failed, are you breaking them or are they just not cutting?
Im in Glendora. If you are willing to give it a shot I can throw a few bucks your way.It isn't hardened, you are either using a dull twist drill or you are spinning the drill too fast.
Where are you in SoCal?
Close to Riverside?
Brian
Bring it by tonight, or first thing tommorrow and Ill do it while you wait.Im in Glendora. If you are willing to give it a shot I can throw a few bucks your way.
Did someone say "laser?"you will be either looking for a laser guy to get the drill out,
tell me when and where is good for you and I will be thereBring it by tonight, or first thing tommorrow and Ill do it while you wait.
Sent you a PM.tell me when and where is good for you and I will be there
they work well IF you can find em... a quality nitrided 10% cobalt bit (the gold ones in a black and decker set) should take it out...lh drill bit and drill slow, it'll catch and make the bolt back out![]()
I never thought to ask if THE HEAD WAS OFF. Dammit.
Thanks for the info Mike. Always happy to learn something newIf its broken off down inside a hole you may have to hit it with a small end mill to get a flat surface to drill into. The angle breaks are kind of a bitch. Tough to do on vehicle. Once you get a hole in it (I'd use a cobalt drill) using cutting oil at a relatively slow speed then soak in a 50-50 mix of acetone and atf (best thread release known to man) and use appropriate size easy out.
That is a good tip! Thanks Mike.Thanks for the info Mike. Always happy to learn something new
One thing on my bucket-list was to agree with John on something. I've found it! I'll also thank you for the tip, Mike!Thanks for the info Mike. Always happy to learn something new
