How do you guys clean steel aircleaners short of submerging them in a bucket of solvent?
Gumout Carb cleaner.
And do make sure you pull it off to clean it.
S CP :D
Screamin SeaMonkees
Take it off...
Put it in a three gallon pail and submerge it in Laquer thinner. Let it set, shake it around and then remove to blow dry, from the inside out.
I used a can of brake clean and it worked great. I doubt the silicone sealer used on the upper and lower seams will tolerate that many times.
What the Hell is That?
I used to use LPS Pre-solve. That stuff is Great!
