1 - 1 of 1 Posts
BUILDER-PAINTER
#1 Blown injected on Alcohol - 496 BBC chevy tall deckblock half filled-4.250 valasco crank- oliver billet main caps-groden aluminum rods-ross pistons-total seal gapless rings-isky 802 lift cam-comp cam roller lifters and push rods- stainless steel comp rocker-crane stud girdles-merlin grumpy jenkins iron heads-ferrari valves-k-motion springs-enderle 110 pump-littlefield tall deck blower manifold with burst panel-bds 871 teflon strip blower-enderle bird catcher - set up by kj crawford with high speed bypass and nozzles-moroso 10 quart shoebox oil pan-engine has 6 1/8 passes, like new.
$13,000
#2 New 500ci using a Chevy bowtie block as the base. It has two Holley 1050 carbs that have been worked over by Advance Engine Development out of Richmond Virginia with air bleeds and all the goodies. These are fed by an Enderle 80A fuel pump feeding a BG 4 port regulator, all this sits on a custom made sheet aluminum intake. The heads are aluminum Pontiac flowed and set up by Morgan Machine. It has a Jesel belt drive as well as Jesel rockers and a Fluid damper. On the inside there are BME aluminum rods and pistons with Childes & Albert rings. It has a Weaver Brothers 4 stage dry sump oil system with an aluminum Hamburger dry sump pan and system 1 oil filter. There is a high torque mini starter (15-1 comp.) along with all MSD ignition system including a crank trigger, billet low pro distributer,
$15,000
#3 495 BOWTIE BLOCK TALL DECK,BRC 4”CRANK,CARRILLO RODS 6.4
JE PISTONS 13.5,LUNATI ROLLER CAM,ISK LIFTERS,CHROME JESEL BELT
ATI BALANCER,
POLISHED BRODIX HEADS, TITANIUM VALVES, NEW SPRINGS, JESEL ROCKERS
POLISHED DART TUNNEL RAM,1050s GARY WILLIAMS CARBS
OFFSET VERTEX MAG
HAS RACE PUMP FUEL PUMP
DROP IN AND GO
$12,000
FIRST 10 PICS OR ENGINES LISTED
NEXT IS A 540, NEXT 572, NEXT 477 ALUMINUM 14 DEGREE BIG CHIEF, NEXT 500 BIG CHIEF ENGINE, NEXT 572 BIG CHIEF ENGINE, ALSO GOING TO HAVE 468-496-555-565-572-598
ALSO GOING TO BE SELLING LOTS OF BBC PARTS,
IF YOU MESSAGE ME AND YOUR NOT GETTING A MESSAGE BACK FROM ME. MOST OF THE TIME IT TELL ME PEOPLE ARE NOT RECEIVING MESSAGE. PLEASE TEXT ME. THANKS
BEST TO TEXT ME
SIX18-567-ONE80FOUR
1 - 1 of 1 Posts
