1 - 1 of 1 Posts
cleaning shop. i've got a bunch of stuff that i am tired of moving around. heres the list:
complete polished B&M 250 blower, for sbc. manifold, 250 blower, 2-780 blower carbs, b&m hi-tek valve covers, matched cam and lifter set(488/510 lift, 288/292 duration),bds linkage, blower scoop with filters(black krinkle), idler, belt, top and bottom pulleys, crank hub.....never had fuel ran thru it....new.....2600.00
BBC ATI INTERNAL DAMPNER---916890...GOLD ONE....NOT REAL PRETTY BUT IT WORKS.....175.00
BBC EXTERNAL FLUID DAMPNER.....100.00
3 DOMINATOR TOP MANIFOLDS ALL FOR SHORT DECK BBC: 1)DART DRILLED AND TAPPED FOR FOGGER---225.00 2) VICTOR 454R---175.00, 3) VICTOR 454R POLISHED WITH FOGGER LINES AND POLISHED SUPER POWER SHOT NOIDS AND 1050 DOMINATOR----750.00 THESE ARE ALL FOR BIG PORT HEADS
MALLORY 4 PORT BILLET REGULATOR AND FUEL FILTER----150.00
BIGGS 1050 DOMINATOR 9375---475.00 OR 400.00 W/ PURCHASE OF A MANIFOLD
1 SET OF SBC CROWER ROLLER LIFTERS--.874---NICE-----225.00
STANDARD SIZE SBC CROWER LIFTERS MINUS ONE PAIR----150.00
6 BME ALUMINUM RODS .250 LONG W/ 4 DYNO PULLS WITH 6 ROSS 4.5 BORE PISTONS---350.00
PAIR OF CHASSIS ENGINEERING FRONT SHOCKS FOR 64-67 A-BODY OR PROBABLY FOR 67-69 CAMARO ALSO----40.00
CSI BILLET THROTTLE BRACKET AND MORSE CABLE----60.00-FOR DOMINATOR
SCAT 4.0" CRANK 4340 NEEDS TURNED 10/10---250.00
EAGLE CAST 400 CRANK BRAND NEW---125.00
BBC 502 RECANGLE PORT HEADS WITH FRESH VALVE JOB NO VALVES--400.00
NARROWED DAN 60 SUMMERS AXLES, SPOOL, 5.57 PRO GEARS, 43" OUT-OUT--500.00
9 INCH HOUSING AND MOSER 35 SPLINE AXLES(AXLES ARE BRAND NEW), AND 35 SPLINE SPOOL, AND 4.56 R/P, NO 3RD MEMBER 850.00 OR 400.00 FOR JUST HOUSING
64-69 LEAF SPRING 12 BOLT POSI, 4.88 GEARS,-NO SPRING PERCHES, 54 1/2" INSIDE TO INSIDE---800.00
CAL TRAC SPLIT MONO'S LIKE NEW FOR 68-74 NOVA----175.00
BBC TEAM-G ALUMINUM WATER PUMP--PAINTED BLACK, --NEW--75.00
ALL PARTS ARE PLUS SHIPPING CALL JW @ 530-870-2240 I NEED YOUR EMAIL TO SEND PICS. [email protected]
1 - 1 of 1 Posts
