Hi, Just wanted to know if a Crack in no#2 Main saddle is at all repairable it is straight across the oil passage and goes down the saddle almost 1/4inch, It is a bowtie 184 block, 4 bolt splayed caps, I spun a rod bearing and there was obviously excessive heat, Crank is no good. Just wanted to know if I can salvage this block in anyway. I have tried to attached photos i hope they work and thanks for any infomation.
Generally, many cylinder blocks with a cracked main such as your example (due to spun bearing/overheating) can indeed be repaired and put back into service. The big question is whether to execute such a repair on that Bowtie block and then re-utilize it in a high performance application. And while that has been done successfully, the percentage of risk goes up notably depending on the details of the usage. For example:
I've known of similar damage to stock blocks which were simply left untouched/not repaired, align honed, stock engine rebuilt, then rebuilt put back into service again without issue for tens of thousands of miles without issue--just don't overheat the engine again or it's over.
Moving up the ladder a bit, if one had a numbers matching LS6 454 Chevelle or 440 Super Bee with a similar failure, Id definitely stitch the main and sleeve the oil passage and put it back in the restored car.
There is nothing wrong with a properly repaired component.
But when the block is going to be subjected to stresses that cause it to wiggle around more, all bets are off. I do know a guy who ran a factory 4-bolt Cobra Jet block in a pulling truck that saw more than 9500 RPM on every pull and be did this for a full season. Identical cracked main that was repaired. By the way, factory SCJ blocks have doweled main caps which probably helped hold/pull the two sides of the cracked (repaired) main toward each other...but during season 2, that baby let go hard.
So it really depends on a lot of variables, such as extent of failure, quality of repair, final usage. For a marine application such as yours, I'd replace that Bowtie block but I'd definitely keep the broken one and fix it and "retire" it for use in something mild duty.
LO
