what are most guys having the best luck with? what brand is the lightest and best? we're 1/2 filling a standard deck bbc up to the freeze plugs and not sure what brand to go with and how much we'll need.
lol, that's what my uncle's machinist saidquickcrete use a 80lb bag mix with warm watersorry couldnt hepl myself
grn
rehr uses the hardblok brand?try ( hard bloc) is the name and can be found almost anywhere on the web
try www.competitionproducts.com
http://www.rehermorrison.com/
http://www.raceeng.com/.............. these people are the best out there . !!!
moroso also has a version of it
i'm just curious?...what r u building...a rocket ship??i need something that is really gonna reinforce the webbing, this thing will see 30+lbs boost![]()
tom i hope you learned your lesson on the last gm blocki need something that is really gonna reinforce the webbing, this thing will see 30+lbs boost![]()
i agreeWe have used the Moroso block filler in all of our drag racing engines with good luck (Moroso part #35570).
If this is a GM block, you might as well not waste your time putting it together if you're going to run 30lbs of boost.
Jim I do not think you need block filler unless you are running mega HP and or Boost and a Dart block is already stronger than a stock block! WTI have a brand new Dart block.
Should I even be thinking of doing a 1/2 fill?????
Jim
Darrell, Filling a stock block keeps the block from destorting under hard load and high RPM! Just my .02 WTHey guys, just reading through the thread, and wondering. What's the advantage of filling the block? Strength only?
PS> Is this used for drag racing only?
Darrell.
509 BBC at 15 lbs running corn.Jim I do not think you need block filler unless you are running mega HP and or Boost and a Dart block is already stronger than a stock block! WTdevil
its not my motor, i just put it down on paper and i'm helping with the build,ordering partstom i hope you learned your lesson on the last gm blocktell billy to buy a good damn block so there is no problems:|errif not okay milkshake time again
