I put some 215 lbs of weight on a scale & calibrated it @ 215 lbs then I put a 5 lb weight on the scale & set a 396 bbc bored .030 over on it. 180lbs for a 9.8 mark IV ,no main caps! so I went back out & reweighed & i got 185 lbs,( could have bumped dail).+ 20lbs for the main caps =200lbs -205lbs with mains. anybody know what a 454 weighs at different bore sizes & deck heights? pics & actual weighing for an accurate info needed. please ad to this thread as the internet is all over the place on weights . include dart blocks etc. too as some specs just don't add up. 8lb difference on an aluminum tall vs short deck on dart but no specs tall to short on iron blocks. bowtie says only 7lbs difference short to tall on iron blocks. iron difference should weight more than alumn. I would think? thanks , hopefully this could be a very informative thread
.( the fuzzy pic is 210lbs -5 for the weight it is balanced on)
