probably going to need to open up the power valve restriction holes a little, but I would certainly talk to the carb builder before breaking out the drill bits.
probably going to need to open up the power valve restriction holes a little, but I would certainly talk to the carb builder before breaking out the drill bits.Kind of a vague question.. but on a blow thru carb
what would cause the WOT to lean out?
on my nephews boat he can get the air fuel ratio
almost perfect from idle thru cruise but when he
opens it up to WOT it starts leaning out.
fuel pressure is 7 psi at idle, 12 psi under full throttle
5 psi boost.
I know its a Holley by lance patton, (yes he is going to call him) but I'm curious what can cause this.
if he jets up it still leans out under full throttle.
from the dock it sounds like its missing slightly
when it leans out.
here is his target #'s
Idle 13.5 to 13.8
Accelerate 12.2 - 12.5
Cruise no load no boost 13.0 - 13.3
Cruise with small amount of boost and load 12.5 - 12.7
WOT 5 + lbs boost 11.8 - 12.0
everything is on target but his WOT it starts climbing above 12.5.
when it leans out.
Idle 13.5 to 13.8
Looks like you found your answer. Call to make sure and see why the PV's where blocked off.is there any reason both front and back PV would be blocked off??
most guys are just welding on a 2 inch spacer to their hat so it allow more time for the flow to straighten out.I read an article along time ago where they used a flame arrestor inside a bonnet as a de-fuser to straighten out the air. The de-fusser ended up being worth 25 hp (something like that) and it smoothed out the A/F cylinder to cylinder.
S CP![]()
prob a 6.5Still no call back from Lance.....
power valves are plugged primary and secondary
thinking about putting a PV in the primary
any recommendations on what size to start with?
go with the pro hat and be done buyin hatsI noticed the new extreme velocity one had a divider built into
it which split it into 4 sections, I haven't purchased mine yet
but thats the one I'm leaning toward
