1 - 20 of 53 Posts
Boat 502
Hey, just trying to learn a little bit about these "huffer" motors you guys run !:D So my first question is if somebody is running a 468ci w/ a 671 blower 21% over what the hell does that mean as far as compression/power. Is this another term for "boost" ??? Is this thing hauling the mail or is this mild ? Edjimacate me:)sphss
First off, a 468 with a 6-71 is kid sh!t, J/K. Boost is the amount of air forced in when vaccume no longer exists. 21% would be the % over 1to1.
Boat 502
Ok so when you turn up the boost that is going to make that ratio (21%) increase ? Also, adding more boost to a motor is just a pulley swap, right ?
Boat 502
Last questions on this subject.....is there some kind of formula/breakdown to figure how much boost a motor is running if its 21% w/ a 671 ? Also what do you think a little 468ci w/ this set up is making hp wise ????
Cantard
Would need info like what heads you are using.
I think BDS has a chart on their site with the #'s your looking for.
Darrell.
surprised noone has mentioned how hot the intake charge would be at 21% on a unintercooled 6-71. i ran a weiand 6-71 on my 475bbc last summer and there was no noticeable difference between 12% and 21%imo. i was taking out so much timing to keep from detonating the hot intake charge, that imo , it wasn't worth over driving that much unless i had a badass chiller. you start needing to run 21%, than its time for a 8-71:)bulb
Boat 502
I haven't even seen the motor I'm referring to yet. I'm going off what the guy said. I'm so used to talking about n/a motors that I was a little lost w/ the terminology. I motor has a intercooler on it though.
Cantard
x2
I run an aftermarket blower in between a 671 and 871, set up by Littlefield, I run 7.5 pistons, merlin heads 15 % over, 12 lbs. boost WOT 6200 rpm w 32 gears in a 19 Sanger bubble..............runs pump 93 octane w/ 35 degree total timing............... about 60 hrs on motor............ runs mid 90's and punishes "100" MPH boats all day long................ All I gotta say is "It works for me"...................
Cantard
Are you pulling timing as you add boost or do you have it locked in?
MSD centrifugal, full advanced set at 3000 rpm, 8 degrees at idle......... seems so work good ............The curve is adjustable in the distributer. Thinking about buying a 21 v bottom v drive Rayson or Schriada or something of that nature .............. The flat beats an ol' guy up these days, and my wife still hates em'
"It's HONDO, honey"
Hydro, SSI 14-71, 38% overdrive. lots of boost to say the least. Go with an 8 you don't have to overdrive it as much as the 6 and it offers more if you want to up the ratio:D
1 - 20 of 53 Posts
