I recently purchased a new old stock mooneyham 10:71. I have a drive setup of a different blower, BDS to be exact, I thought couplers and snouts were universal when it came to roots setups, but I guess I was mistaken.
I need help identifying which parts, or what needs to be done, to complete the drive/snout setup for this unit. It appears that the main bolt holding the front gear on to the rotor, a large arp 12 point, is too long to accommodate the shaft in my coupler. The shaft within the coupler bottoms out on this nut before the flanges meet. The bolt on the blower goes past the flange face almost a half an inch, whereas the shaft in the snout is pretty much flush with the flange face. I have attached a few pictures for reference.
I guess bottom line, I'm trying to understand if there is a specific snout/coupler for mooneyham blowers, or if there is a specific reason that this spacer and large arp bolt was used. I tried emailing and calling mooneyham with no luck, not sure if there are even around...
Any help on what I need to get the blower drive setup correctly would be greatly appreciated!!
