1 - 3 of 3 Posts
I always give a good look in and around my engine while it's running in the marina before taking off for the day. On Sunday, it looked like I had oil swirling around in my sea strainer. I'm as color blind as anyone so I chalked it up to shitty marina water.
I ran down to the Springs and hung out. At the end of the day, about five minutes on plane the drive gave a really bad screeching and we came to a stop. The smell of gear oil was strong. We didn't get back on the trailer until 11pm and the boat went back into storage. I'm thinking about just picking up a used bravo 1 and letting it rip. Does anyone think the gimble bearing could be bad. I know the drive is bad, but don't know the extent. I can rotate the prop with a little force in gear. If oil is running through my water would the case be broke or just a seal?
bravo b-max
I HAVE A COMPLETE B-MAX 1:30 RATIO POKER RUN EDITION OUTDRIVE. CRESCENT LOWER WITH DRAG PLATE. H/D GIMBAL AND IMCO DUAL STEERING. CAME OUT OF HTM 24SS WITH BLOWN INJECTED 572 CHEV. NO PROBLEMS. CONTACT MARK FETTERMAN AT [email protected]
it might be as bad as you think I can repair save whats good replace whats bad you can call me at 928-486-5416
1 - 3 of 3 Posts
