1 - 7 of 7 Posts
Can't re-Member
I noticed last time I was out that I can hear a growling noise, or slight vibration when I make a hard left turn, but nothing when I turn right. Sounds like it's coming from the outdrive. Anyone have any ideas?
Gimball bearing needs to be checked out, also check for up/down play in the kingpin bushings....Common issue.
New here
Check it also when trimmed slightly up/down and try turning with each. Could also be Ujoints.
Can't re-Member
I was hoping someone was going to tell me 'It's normal, don't worry about it" JK...
Called Kenny, takin it to Eliminator next week.
It's good to be alive
Wait, don't run off. Don't you want four or eight more opinions:D
Your steering wheel is hitting the cup holder....
1 - 7 of 7 Posts
