Another Bravo question: I have a new to me Bravo and had the transom mounted reservior upgraded and filled at the last service. This is my first season with this package, does the reservior need to be refilled often, does the Bravo use gear oil? The outdrive is in like new condition with 260 hours on it.
Thanks
Depending on the age, it may or may NOT have a level sensor in the bottom. If there is a sensor/plug at the bottom of the jug with two wires coming from it, it DOES have one.
If NOT, you need to keep an eye on it - check it ever trip on the way OUT and after back on the trailer - to make sure it hasn't changed much if at all.
Yes, it uses gear lube. 75-90 is the norm, but there is better stuff. Jim Wilkes likes Lubrication Engineers stuff, whereas I have some extreme use-experience with the TORCO I mentioned above. OR, you can always just use Merc Quicksilver. RedLine and AMSoil have some great offerings as well. It depends on how GOOD you want to treat your outdrive. The TORCO is around $20/liter and a B1 takes just over 2 liters. The way I see it - an outdrive is $4000 to $7000, so I get the best synthetic I can find for it. Hence, the TORCO.
If the level goes down, there is a leak. I had one at the coupler/bulkhead fitting in the transom assembly. Leaks can be anywhere from the bottle clear back through the seals in the outdrive itself.
