I have not owned an outdrive for a lot of years-I recently purchased an older (2001) Formula Fastech 292 w/Bravo 1's: First lesson-don't try to trim them up and beach the bow as the low water intakes will suck up stuff and you will idling home for 3.5 hours dumbass.
Anyway-3 questions:
1) I am still getting too hot so should I pull raw water pumps/inspect-pull manifold/risers/inspect to determine blockage (or is there a way to truly flush them out?)
2) Can I get the lower unit with both pick-ups on them including the side mounted ones like I used to have?
3) What is the best option for fresh water flush kit for the 350 Mag MPI w/o using the nose cone on the outdrive? I would like a kit that mounts inside that I can connect the garden hose to.
Thanks in advance from a newbie
Anyway-3 questions:
