The Magic (right before I sold it) had a problem with the trim cylinders. Due to no fault of mine, seems the Bravos have a plastic spacer in them to prevent trimming up any further than they do. Well one of the little buggers disentigrated into a hundred little pieces and of course found it's way thru the entire trim system, costing me the rebuild of trim cylinders, new trim pump and labor to flush out the whole system, pretty costly.
So I would suggest checking those spacers out very carefully, they are inexpensive but cause a lot of damage when exploded. Good Luck.
NSF
PS Oh yeah I forgot, the PlayCraft had a leaking Trim cylinder right after I got it so had both of them rebuilt. Not having a real good run of luck with trim cylinders!!!!!!!!!
