1 - 3 of 3 Posts
You who rock I salute you
On the 2011 502 Merc with Bravo 3 seems to me the water just flows through to the heat ex-changer and back out.
If the separate closed loop, thermostat regulated, glycol system is cooling the engine,, should I really have to wait for the engines to warm or even have to run it to flush it?
Some disagreement at the dealer with the Sea Core over this anywhere from don't need to even flush it, to run water only,,, to run the engine until it warms up and flush
So my question is WTF?
It's what we do
Yes you still need to flush it. The heat exchanger and riser pipes will still see water from what ever body of water you are running in.
Thanks.
1 - 3 of 3 Posts
