I have major gimbal slop i have a twin 454 bravo one set up in my offshore and I can move either drive (cross bar removed) back and forth between 4 and 5 inches before the little arm going through the inside gimbal plate moves at all.... where is the wear or slop? is it the pin that the gimble rotate on? or is it in the gimble ring? it's a ton of slop and actually is scarry to drive when it finally decides to turn it almost flip a U turn,,, and that can be under full throttle... very dangerous actually are the gimbals repairable or do they just need to be replaced all together? thanks so much ronnie
