1 - 1 of 1 Posts
Completely rebuilt Mercruiser Bravo XR outdrive. This drive has not seen water since a full professional rebuild by Extreme Custom Marine. 1.50 gear ratio. This is a late model swept back case style XR. This unit is very clean with no corrosion.
Keeping breaking stock Bravo One drives? A Bravo XR will handle alot more horsepower.
Purchase this drive and get free installation at BJ's Marine, located at 1260 N redgum St Anaheim Ca 92806. SOLD
Contact Bob @ 714-630-3905
Free installation does NOT include any other repairs your boat may need to install an outdrive. It does NOT include any other parts that may need to be replaced to fix your boat. I will thoroughly inspect your transom assembly, gimble bearing, shift cable, bellows, engine alignment and if everything checks out I will install the outdrive at no charge once the outdrive is purchased.
1 - 1 of 1 Posts
