1 - 9 of 9 Posts
How much horsepower can a Bravo3 handle? I am stuck for now with it and want to start engine mods on my 7.4.
I've been throwing a 628hp/652tq 509 at a 2.0/28 labbed prop for over 6 years with no problems....you just have to be smart and not hammer it out of the hole....
deckboat owner
I believe the upper is same between the two. You can either swap the drives, or just the lower and end up with a single prop Bravo. You lose some speed from the extra drag of the 2nd prop and longer cavitation plate in the water. I liked mine like I said in your engine thread. I used to take some faster higher powered boats off the line and up to 50-55. It took a long time for them to catch up. I like it when docking too. I won't argue it's not for everyone, but my family was usually aboard so I didn't miss the last few mph's often. But if you ever do get the itch, just swap lower units, and there you go. I would imagine, but never heard, that the torque limit may be a bit lower for a BIII thought. I have to imagine that the prop shafts would be weaker. Maybe that isn't a factor though too. Seen quite a few big cruisers with 502s and 496 mags ahead of BIIIs, so for sure you can put that much to 'em. The weight/size of your boat and how you drive will determine how hard you can beat on it, and maybe a drive shower if it runs HOT all the time. But you see some CRAZY hp ahead of stock Bravos and other than taking it easier on holes shots, I wouldn't think you would have to treat the BIII too much nicer.
Good Luck!
It's what we do
The uppers are the same. However you will find that 90% of Bravo III's have a much lower gear ratio than you would use with a Bravo One and the gear ratio on a Bravo One is changed in the upper. If your BIII has a 2.2:1ratio, you will have a hard time finding a prop to work if you put a Bravo One lower on it.
Platinum Member
X2 :)hand some boats do well with a Bravo 3
the uppers are the same. However you will find that 90% of bravo iii's have a much lower gear ratio than you would use with a bravo one and the gear ratio on a bravo one is changed in the upper. If your biii has a 2.2:1ratio, you will have a hard time finding a prop to work if you put a bravo one lower on it.
x2 x3 x4...
My Stingray 230LX with a 450hp 383 went 69 with a Bravo 3, 70.2 with a Std Bravo 1, and 71.2 with a -2 sportmaster on the B1 drive. I'm spinning my motor at 6100 RPM max. Just keep them cool and try not to push the gears through the upper cap on takeoff.
bravo 3
i have some props for sale. 2sets of 28 and two sets of 30 pitch props 4 sets in all 500 per set perfect shape 1-530-400-6201 if you need them
1 - 9 of 9 Posts
