1 - 9 of 9 Posts
whats the total length you need,thickness of the bulkhead
the standard bulkhead fitting is 2 7/8 total length the problem is the fitting goes thru the transom and I can put the nut but there is not enough to put the hose end fitting on and tighten up I need another inch of shoulder to go thru the transom then every thing will tighten up:bangmyhead:
1 - 9 of 9 Posts
