1 - 13 of 13 Posts
You'd think I'd luck out on 1 of em ....not . short of cable tying them to the transom any sugestions on how to get them all off my header?
Swollen Member
Reroute the cable a different way, thats about it, or make a heat sleeve to put around it but i would reroute it personally.
I think I could tie em up kinda where the gunnel meets the transom, maybe I'll have to go under with the diverter and fwd/rev.I'll try to put up a different angle, its pretty tight underneath. any reroute sugestions?
Slow down, tkae your time and clean those wires up! Plug wires should route from below.
Aww come on brendella that looks purdy, haha. It didn't look quite that bad until I pulled my driveline and my starter, I just kind of stuffed em all up there. The diverter cable seems happy underneath, but the other 2 I think need to be attatched somehow to my gunnel.
I'm not going to get to anal about the wires, because that dist./ ignition is going bye,bye. my transom is 4" thick so I had to take a hole saw half way through from the inside to get the splashwell to piviot o.k. BTW can someone tell me how to make them pics bigger?
It is a setting in your camara you have to change to make them larger or smaller! Go to menu and play! LMAO!:D
21 Daytona
This is an outboard conversion, that cut out part
had a hinged pad on it, thats why it looks like that.
Whattya Expect For 3800.00
Are you guys talking about how the back of the boat/top of transom looks like it was cut off by a beaver, hahaha , when I bought the boat I thought it was "born" an outboard .Tom (jbp) told me it was orig. set up half wacker(i/o) then somebody turned it clip on, poor bitch has been everything, I plugged upward of 50 holes in the stringers.....anyway I swore I wouldn't turn my project into a paint job until it ran first(prolly next winter). I think I got the cable thing figured ,I had to reroute and bend the steering more than I would have liked but it seems to work o.k.:)grn
1 - 13 of 13 Posts
