im running a 496 14-71 blower with chiller i need some feed back on this cam,is it right ,will it work,i dont no 4 my aplication,it ran in a 19 daytona,like a cheeta on steriods, herbert cam , lift-.698-int ,700 ex, duration advertised, 304-int ,313 ex, duration @ .050 269-int ,275 ex, valve lash, .025-int ,.025 ex, center line 106, the lobe center,112, heads r eddle brock performer rpm marine heads. any feed back will be great
u need to get ahold of cstraub69 on the boards...he grinds cams for all applications & can help u...i personally think the 14-71 is a little over-kill!!...i'm building a blown 496 & am gonna run a Mega 420 with a chiller & Holley 450cfm carbs...not set on the cam yet, but will prob run 1 that will give me low end torque & mid range power...its going in a '73/76 Kona 18' with Berk jet etc...just my .02 cents
FastRat
what did chet say ?
112 is too tight.
116 is better.
FastRat
450 carbs? You running a V-6 ?
Blower cam, no need for advance, huffer will stuff it in there, needs to be 112 straight up. Ebrock heads need more exhaust crutch then what you have there. . .about 14 to 16 degree of split at .050. I'd say present cam is smothering engine because not enough duration to evac exahaust.
Well said.
